Lifter Galley Cover Question
Old May 14, 2018 | 09:05 AM
L33's Avatar
L33
Default Lifter Galley Cover Question
I have a 2005 L33 5.3.
The intake manifold i am using is from a CTS-V (LS6 Intake with cable pull TB)
I am running a LS2 water pump with 3/4" spacers.
Will my L33 Galley Cover accomodate this setup or will I need modification and/or a different cover?
TIA
Old May 15, 2018 | 07:38 AM
leftysrepsol's Avatar
I switched to an LS6 valley cover with the PCV built in to try and help with the oil in the intake issue motors have. Also installed a catch can too. The steam vent tubes and bolt height might cause you clearance issues
Old May 15, 2018 | 07:44 AM
L33's Avatar
L33
My cover is just a straight piece of aluminum... no vents or anything other than knock sensor cavities...
It is an 05 L33 5.3 which I believe has alot of gen IV technology.
I just dont know for sure, figured somebody might?
