Voltage dropping when car is hot
Hey guys, I've seen quite a few threads about voltage issues but none really match my symptoms. I have a 2002 z28, no aftermarket sound system or other additional electrical loads other than factory. I noticed after acceleration and I'd left off the throttle my voltage gauge would dip to around 13 and then back up to 13.5-14 range after a second. Before this I noticed all the lights in the car would flicker when in drive at a stop. I replaced the alternator and while it was off, a new belt as well. After this it still did it and I tested my battery, which was bad so that got replaced as well. I also cleaned off all my grounds as precaution These problems have since gone away. Now I'm noticing when that car is first started my voltage gauge in the car reads over 14, close to the tick between 13 and 18 on the gauge. As the car warms up it slowly makes it way down closer to 13. I only work 20 or so minutes away so I dont know if it will get even lower with time but is this normal or should I be looking for something else wrong? I know GM gauges can be a little inaccurate too with age, like all the fuel gauges so that also crossed my mind.
Reason: Missing information
