Upgrading to a 250 amp alternator
I'd run at least a 1/0 gauge for that many amps.
I would also upgrade the ground from the battery to the body, the battery to engine is already a pretty good sized wire and will do fine but some people like to upgrade that one too.
250 amps??? At 12 volts? That's 3000 watts of power. I'm guessing a VERY large stereo?
Rick
Rick
1/0 ga from alternator post to positive battery post with a 250a fuse in-line
1/0 ga from alternator chassis to negative battery terminal
I also ran an extra 4 ga from the negative batt terminal to the block ground on the pass side, as well as a 4 ga from the drivers side of the block (where the ancillary bracket for the factory alt bolted on) to the chassis ground on the drivers side frame rail (on the factory, this has a small ground strap bolted there)
Out of curiosity, what brand alternator are you going with?
