anyone ever shim the trans bracket
Old Jul 6, 2018 | 09:42 AM
trilkb's Avatar
Default anyone ever shim the trans bracket
So I put pacesetter LT's on my car and texas speed ORY, to a flopro twister on a SLP LM2 catback.
The headers hit the heat shields and the y pipe hits the frame when shifting, when I get on it I feel like the headers just slam into the body and stay there until I let off.
Im curious if I could just shim the trans bracket like 1/4 inch or so to drop the headers away from the car? Is changing the drivetrain geometry the worst idea ever?
Do people just cut off the heatshield? Its basically resting on the header on the pass side. I dont think new motor mounts would fix it because wouldnt that get the engine higer if they are sagging? jamming the header collectors even closer to the car?
Old Jul 7, 2018 | 07:05 PM
jhshnh's Avatar
Remove all heat shields for headers. What you're seeing is common with headers.
I would wrap the part of the exhaust that hits the frame with header wrap. This prevents the annoying rattling.
Old Jul 7, 2018 | 07:06 PM
jhshnh's Avatar
But I wouldn't shim the trans cross member.
Old Sep 26, 2018 | 12:11 PM
trilkb's Avatar
Just saw this answer. thank you. I havent touched it, just dealt with the noise, if I can access the bolts Ill try to get the heatshields off. I bought some wrap too.
