Recommendations Drive Accessory Truck
Who has recommendations for AC and/or PS pump relocation brackets for Vortec Lq4. I'd ideally like to keep my fixed displacement truck AC compressor (as its a good compressor) but most of relocation brackets I've seen seem to be more geared to Sanden etc.
Who did you use and like.
I can make it all fit within the frames - but its tight on lines ..........so just weighing up
1) Relocate to TOP
2) Buy an AC crimp line tool and make some custom lines.
https://www.ebay.com/itm/NEW-PREMIUM...itleDesc=0%7C0
3) Other.
This seems to be the best kit I can find .......... but requires new AC compressor and I cant really quite work out what its doing to the Alternator etc except lowering it just a little which I dont think I need. My issue on drivers side is mainly the PS lines and the Oil Cooler lines interfering with the rack and pinion shaft. At least its very tight.
https://www.ebay.com/itm/Dirty-Dingo...sid=m570.l1313
Do you know if they have a PS relocation for truck spacing ......... I see AC and Alt .... but not PS on their website.
Sort of like this one - but doesnt look like the PS pump moved just the AC and ALT.
http://www.lssimple.net/click-here-t...gh-mount-combo
