Flushing Coolant System Questions- 01 SS
Am I ok to use a standard coolant like Prestone, Peak, or do I need any special kind? At this point I'm planning on using a regular green coolant. I'm not a fan of Dex Cool, seems to break down and get nasty as it gets older.
Using Distilled water is a complete waste. 20+ years here with my 1998 Trans Am and hose water....everything is fine.
No need to install a Flushing Tee..........
Simply remove your t-stat.....then put the t-stat housing back on with just one bolt holding it on.......drain your radiator, put the drain plug back in. Fill the radiator with 75/25 water / (((aluminum safe)) degreaser like Formula 88 from Home Depot. Run it for 15-20 min at idle WITH RADIATOR CAP OFF so no pressure builds up. Then let it sit for a couple hours. Then drain the radiator. Then refill the radiator and put the hose in the radiator on medium. Start it back up and let it run and rinse/drain until the water is coming out clear......
****Note: Check coolant temp frequently so it does not overheat for some reason.
You're not gonna get a better flush than that.
Removing freeze plugs and other crap.....thats for engines that are completely blocked by sludge or other kind of strange **** that somehow got in there.
If you want a cooler running engine and a much cleaner coolant system.....GO GREEN coolant......whatever brand you want. I went GREEN years and years ago....best move I ever made. Dexcool is ****........
I think I might have an air pocket stuck somewhere, any ideas?
You don't need to spend this much, I just figured I'd link you to the one I use.
https://store.snapon.com/Cooling-Sys...l-P888852.aspx
Keep in mind that the temp gauge is incredibly inaccurate. I have a 160* thermostat and a scan gauge. The gauge in the dash is always a little before 210, where as the scan gauge reads 20-30* cooler.
I agree that the factory temp gauge seems to be very inaccurate, I was told my car had a 160* t-stat in it when I got it, the temp gauge always hung out a little below the 210* mark on the gauge, When I replaced the water pump I changed the t-stat and saw it it a 160*
