TPS voltage question
Old Aug 17, 2018 | 05:34 PM
Dano 00TA's Avatar
Default TPS voltage question
I have my TPS set at .50 at idle but full throttle only takes it to 4.24 I know of the bump stop mod but it looks like if I grind that much the blade will go past full open. I also read that the voltage is important on A4 cars? HP Tuners says I'm at 100% open already. Does the voltage matter as much as it being 100% open?
Old Aug 18, 2018 | 12:52 PM
pantera_efi's Avatar
Default TPS Voltage at WOT = 100%
Hi Dano, the Voltage is fine, the HP "read" of 100 % at WOT IS IMPORTANT.
Lance
Old Aug 18, 2018 | 12:56 PM
Dano 00TA's Avatar
Thanks! I was hoping to not start grinding on my new throttle body.
