Not sure what fitting needed.
Old Sep 16, 2018 | 03:16 PM
Philhippy45's Avatar
Default Not sure what fitting needed.
I bought a fast 102 intake from a guy and it had a ls3 fuel rail mounted to it. But we're the fuel line plugs into it it's the quick connect like stock it's a threaded fitting. My question is does anyone know the fittings I need and also has anyone seem this before? It measures about 14mm across.
Old Sep 16, 2018 | 04:14 PM
8.Lug's Avatar
It’s an AN fitting. It’s an English/imperial standard so it’s not 14mm, it’s 9/16” which would mean that’s a -6.
Old Sep 16, 2018 | 05:21 PM
ah ok thank you very much. So I need a -6 an fitting do they make braided lines with the -6 an on one end and a 3/8 on the other for the stock fuel line?
Old Sep 16, 2018 | 07:56 PM
8.Lug's Avatar
AN fittings are used in custom applications to fit a specific setup - that’s kind of the point of them. I’m sure with some searching you can find something pre-made that will fit your application - but it’s really a DIY thing.
