Quick steam vent question
Old Oct 9, 2018 | 08:50 AM
02ws666's Avatar
Default Quick steam vent question
Hey all,
I bought the truck motor rear steam crossover which has the vertical outlet. I have that routed to the front of the car and will want to T it together with the front crossover. Will just a simple copper T suffice? OK if all 3 ends of the T are the same size, or does the single end of the T(that goes to the radiator) HAVE to be bigger? Do I need to put some sort of check valve to prevent the steam from going back in or down the alternate side.
Just want to make sure I plumb it correctly.
Thanks
Old Oct 9, 2018 | 10:11 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
I think you mean brass not copper? You can use brass, plastic, steel, or nylon, any will work ok.
Old Oct 9, 2018 | 11:45 AM
02ws666's Avatar
Yes Brass my bad. Just wanted to make sure its ok to run each vent hose into the T without issues. Or if a check valve or anything special was required. Was worried about say, steam from the rear hitting the T and routing to the front hose instead of the Radiator. Might be a dumb questions just wanted to make sure I do it right.
Old Oct 9, 2018 | 12:55 PM
The pressure will come up from each port so no real issue there. Most of the water collection kits use a fancy manifold block. No difference really.
