Knock sensor relocation?? 6.0L iron block
Old Oct 15, 2018 | 01:04 PM
91 Z28's Avatar
Default Knock sensor relocation?? 6.0L iron block
To those of you relocating your knock sensors from the under the valley cover where'd you end up putting them?? Did you just drill and tap a spot on the block?? Trying to figure it all out
Old Oct 15, 2018 | 01:16 PM
There should be some holes on the side of the block that are the right thread, or you could drill out/retap one that is more conveniently located. Gen IV's are located on the side of the block also.
Old Oct 15, 2018 | 01:34 PM
91 Z28's Avatar
Thanks. I'll have to check it out again I been kinda stumped on it
