Rasp!!!!
Old Jul 10, 2004 | 11:36 AM
Ryan02SS's Avatar
My DD muffler on my CME setup sounded good with LT's @ ORY but my SLP muffler puked out all the packing and it became loud as hell and started resonating inside horribly. I then went with Corsa and loved the deepness and tone but that sucker was loud with an ORY. Not much rasp with an ORY but noticeable around 2200-2800rpms. Adding a bullet in the I pipe helped but it was still too loud. Adding cats made everything perfect and it sounds great now. No rasp whatsoever.
Old Jul 10, 2004 | 07:10 PM
shep28's Avatar
Listen to these and decide-
http://dodds.cc/chad/garage/z28/ls1_sounds/
Old Jul 10, 2004 | 08:11 PM
calongo_SS's Avatar
Originally Posted by SSCamaro99_3
True Duals
I agree after getting my TD's I say screw Y pipes.
Old Jul 10, 2004 | 08:21 PM
90GMC1500's Avatar
When you all say "rasp" are you referring to the small backfires when you let of the gas and in between shifts?
Old Jul 10, 2004 | 10:09 PM
blkZ28spt's Avatar
No...
Old Jul 11, 2004 | 02:03 AM
Judd's Avatar
I have a factory SLP DD cat-back on my Firehawk with an off-road Y-pipe. As WILWAXU {I think that's who it was} said, it still has a bit of "rasp" to it between about 2 grand and 3 grand. Below 2 grand- fine,,,, above 3 grand- fine. Sounds perfect {at least to me} at idle and at high rpm.
The rasp gets on my nerves a bit, especially considering that it's centered right in the middle of the rpm range that you are in most of the time. I have thought about putting a bullet in the I pipe but once I got under there, I saw that I would have to cut my cat-back to install the bullet. I was hopeing to only have to cut the Y-pipe. The bullet's case would also be pretty close to my floor. I think I'll just live with it.
