Coolant hose routing?
Old Nov 7, 2018 | 09:11 PM
Jekyllandhyde's Avatar
Default Coolant hose routing?
So I just installed an LS6 intake manifold and elected to keep the rear steam vents piped rather than blocking them off. I used the LS6 steam pipe for the front and I used the truck LS engine steam pipe at the back and intend to run coolant hose to a T fitting to connect the front. Thing is, I have to keep emissions so the Evap purge solenoid needs to stay and im trying not to route the hose near the fuel lines or rail. Any other ideas on how to route the coolant hose to the front? Will it be ok near the fuel lines if I heat wrap it? Thanks.
