LS6 Intake Swap
Any information helps. Thanks in advance.
Anyway, the reason is I like the performance improvement of the intake and I have been informed that it will handle the psi from the turbo better than the ls1 intake. However, I don't want to change any of the cooling properties of the stock set up as it was designed pretty well. Now I could just be wrong in thinking that the performance increase of the turbo set up combined with the blocks in the back of the cooling ports might have adverse effects on the running temp of the motor, and if that is the case I wouldn't mind doing it. I just don't know enough about the blocking set up to know if it is going to negatively effect my running temp when its under high rpm and boost for longer stretches of time, like during a few laps on a road track.
Am I way off here?
This setup works exactly like the tubes under the LS1 Intake with no need to shave the bottom of your LS6.
The Crossovers are available, provided you're willing to give the Auctioneer the asking price.
