Injector help
Old Nov 25, 2018 | 03:24 PM
underpowered's Avatar
Default Injector help
slight build on my LQ4, need info on what injectors to go with.
Small cam (220/228 @50 and .600"lift all around), 706 heads on stock dished pistons, 98-02 camaro headers. otherwise, all stock truck intake and all.
based on what i can find online, the i will be pretty well at the limit of the stock, 26#(?) injectors as i estimate about 450 HP or so at the crank, maybe a touch more. thinking 42# LS3 take outs as i know they are of good quality and can be had cheaply off ebay and from other sources. Would i be better off with a smaller injector, or keeping the stock ones?
Old Nov 25, 2018 | 09:14 PM
LilJayV10's Avatar
They will be big enough but you will need the correct injector data for the PCM you have.
It's not just a copy/paste from the E38 data to your PCM. I know there are several threads on the HPT forum and I think on here too talking about converting the data from the newer PCM's for the 411's.
Old Nov 25, 2018 | 09:24 PM
98CayenneT/A's Avatar
GTP injectors. $100 for a set of 8.
That's what I run with the setup in my sig.
