Pulling timing vs horsepower
Old Dec 8, 2018 | 10:04 PM
fastlt1's Avatar
Default Pulling timing vs horsepower
On a stock ls1 say 300 whp. Pulling 5 degrees of timing. How much whp is it robbing
Old Dec 8, 2018 | 11:06 PM
subeone's Avatar
depends how far off from MBT or peak timing the fuel can handle. The further you get, the more you generally lose. So the first 2 or 3 degrees you might lose 4 hp each, but after the 4th or 5th, each degree could have more weight at 10 hp each for example. This is an effect of deviating from the apex of a concave parabola. It is NOT linear. This is apparent in the Gen V, and Gen IV torque tables in which the torque model solution is a complex polynomial, non-linear relationship.
