Originally Posted by Amurphy
(Post 20020381)
Update guys. A gates belt from orileys fixed the problem. I guess the $18 belts weren't good enough. Good to hear. Hope the noise stays gone for ya. Sometimes a new belt does the trick and sometimes it stays quiet for a few days then comes back and it may wait until the first humid or rainy day before it returns. If so post back up and we can continue to help you find it. Hoping it's fixed though! I'll post a video in a second. After all this talk I had a car come in today with a belt squeal and the customer applied belt dressing and made the problem worse, as it usually does. |
I made this video today. Had a car come in this morning with a squeaky belt and the customer tried belt dressing that didn't help any. Hope this helps a little. |
Nice video! Good illustrative instruction on SQUEEEEEEEKY belts! |
Originally Posted by G Atsma
(Post 20020556)
Nice video! Good illustrative instruction on SQUEEEEEEEKY belts! Appreciate it. A squeaky belt is one hell of a nuisance so I feel OP's pain. |
And a follow up. |
Porter, are you a GM Tech, or do you work for a chain store? |
(Post 20020572)
Porter, are you a GM Tech, or do you work for a chain store? Never worked at a dealer. I was an account manager for a few years and had dealerships as my accounts, but that's the closest I've came to working at a dealer. |
Belt dressing made my belts squeal louder. I bet all the new belts I used cleaned it from the pulleys |
(Post 20020592)
Belt dressing made my belts squeal louder. I bet all the new belts I used cleaned it from the pulleys Yep that's the way it goes. And lol, They probably did. |
In my experience the belt dressing usually makes it worse lol . The longest lasting band aid fix that I have found is ... please dont shoot me for this ...put some of the black silicone stuff , it has worked for me every time. |
Originally Posted by Lsx Rubi
(Post 20021384)
RTV silicone sealer , surprisingly it doesn't make a big mess either . |
(Post 20021812)
RTV silicone sealer , surprisingly it doesn't make a big mess either . It sounds like a super redneck rig up btw lol |
Originally Posted by 00pooterSS
(Post 20022044)
Yeah it should dry up and not sling all over like a spray liquid will. How are you putting it on there? Are you coating the whole belt with it? It sounds like a super redneck rig up btw lol |
Smear it on the ribbed side with the engine running..... so how many fingers you have left? If any.... |
(Post 20022105)
I know it sounds really bad but hey give it a shot next time and see for yourself lol . All I do is smear it on the ribbed side with the engine running . It does sound really redneck if I were to coat it and let it dry and throw it on haha I was just curious, I couldn't picture how or what you were doing. I personally would never do it because it's too easy to just change the belt. That and having silicone all in the pulleys isn't something I'm interested in. |
There's only one thing I've ever found that does truly work. I've tried soaps, wax, chalk, oil, belt dressing, water, brake cleaner... you name it. The only thing I've found that helps is taking a wire brush and holding against the belt as the engine runs. It will clean the belt and knock some of the glaze off the rubber and quieten it down. Belts are kinda soft, almost like they have a lint on them when you get them (in the ribs). Over time they glaze over kinda like a brake rotor does. And once they get like that it's time to change them because they will squeak a little from the hard/glazed surface. A wire brush will take some off that off and get to some of the fresh rubber underneath and help quieten them down. That being said, it's still like 20 minutes and 30 dollars to just change it and be done with it. I don't like messing with things over and over or doing things that cause other issues, so I just change them and move on to other things that need attention, there's always something. Especially when you have a house, boat, wife and kids. That and when I fix things right, the repair lasts for years and I can cut down my to do list. Band aiding things means I have to keep messing with things more often and then I always have 10 things on the list and it aggravates the hell out of me. |
This thread was quite entertaining. One minute someone is calling another a dipshit and the next they're kissing and making up!! Right on!! Now to offer a little of my experience. I solved my belt chirping years ago with a spray bottle of water and an laser alignment tool. The spray of water confirmed that it was a belt issue... and not a bearing or tension. The power steering pump pulley was a little off so after aligning it .... good to go!! Oh and belt dressing is nasty ... it will cake shit everywhere and then your belt sounds like rice crispy treats jammed in there ..... |
(Post 20022199)
There's only one thing I've ever found that does truly work. I've tried soaps, wax, chalk, oil, belt dressing, water, brake cleaner... you name it. The only thing I've found that helps is taking a wire brush and holding against the belt as the engine runs. |
(Post 20022132)
Smear it on the ribbed side with the engine running..... so how many fingers you have left? If any.... Also have to remember there are other engines than the LS where it takes more than 10 mins to replace the belt . |
© 2024 MH Sub I, LLC dba Internet Brands
