Dropping motor with harness.
Old Dec 29, 2018 | 09:42 AM
VandykeT/A's Avatar
Default Dropping motor with harness.
It’s been a while since I pulled a ls1. Let alone one with abs still in intact. When I drop the motor does the abs wires and starter need to come loose or do they all feed through the harness into the kick panel. I’m thinking I can just unhook both battery cables from the battery/fender well and take it out the bottom.
Old Dec 30, 2018 | 07:50 AM
01ssreda4's Avatar
ABS can stay, its not on the engine harness. I typically pull the starter, but the only thing holding it is the battery cable +. Being that its on top of the starter, I just pull the whole thing and disconnect the wire and put the starter in my parts pile.
