!air Mod
Old Jul 10, 2004 | 01:23 AM
01 Red WS6's Avatar
Default !air Mod
What all needs to be done to get this to work? What do I have to do? DO I have to pull of the air pump?
TIA
Old Jul 10, 2004 | 05:34 AM
Nick D's Avatar
http://www.installuniversity.com
Old Jul 10, 2004 | 02:09 PM
2001 White Ws6's Avatar
2001 cars will require you to plug up the small vacuum tube left behind when you pull all of the tubing out. I have mine plugged up on one of the coil pack bolts. The tube that i'm talkin about is connected to the top of a plastic piece that is at the very back of the intake where the tubes connect.
Old Jul 10, 2004 | 07:35 PM
01 Red WS6's Avatar
I think I know where you are talking about. Do I just unplug the air pump?
Old Jul 10, 2004 | 10:57 PM
When i removed mine i took out the air pump fuses. I think there were one in each fuse box in the engine bay. It also says that there are 2 different fuses for the air pump so i'm sure that's what i did.
Old Jul 12, 2004 | 06:08 PM
01 Red WS6's Avatar
hey you want to come over and do the mod for me??
Im still trying to decide if I want to just block off the air pipe and keep it attached or do I want to remove it all together.
Old Jul 12, 2004 | 06:43 PM
Are you planning in getting headers with no emission provisions? If you are then i'd wait and take it out then. If you do it now then you'll have to make or buy block off plates for where the AIR pipes connect to the exhaust manifolds.
If you need a hand i'll drop by. Just let me know.
Old Jul 12, 2004 | 10:22 PM
01 Red WS6's Avatar
If I get the headers with no emissions do you think Ill have trouble passing inspection here?
 Michael S. Palmer
Old Jul 12, 2004 | 11:23 PM
Shouldn't be a problem...there's many places that will probably let you slide. I got my car inspected the same day i did the install. I watched the guy and he never looked under the car for anything. He had the hood up and scanned for codes so when inspection time rolls around again i'm gonna go to the same place.
If that doesn't work then i have a friend that says he can get a place to pass me.
Old Jul 13, 2004 | 11:07 PM
01 Red WS6's Avatar
How do you like your QTPs? Im thinking of getting those. Ill probably go with the non emissions style because they are cheaper and I think they look better
Old Jul 17, 2004 | 12:13 PM
The headers look great. I'm very pleased with them. Now their ORY i got just plained sucked ***, it didn't fit worth a damn.
Old Jul 17, 2004 | 09:05 PM
01 Red WS6's Avatar
Ive heard alot people say that they have problems with the ory that QTP has. Im thinking that Ill have a custom y made when I get the headers. I may take it to lanes
Old Jul 17, 2004 | 11:41 PM
Yea i would definitely go that route to be sure. I drove my car to lanes with open headers. It's not that far from me. Lane will do great work and is a cool guy. I highly recommend his shop.
Old Jul 18, 2004 | 04:33 PM
01 Red WS6's Avatar
Thats cool Ill have to take my up there when I get the headers. I doubt that I could drive all they way out there with open headers since I live so far away. I would probably be deaf by the time I get there
