Hooker header install
Old Jul 10, 2004 | 05:50 PM
flexybronc's Avatar
Default Hooker header install
I just had my Hooker lt's and ory put on yesterday. I dont know what the hell was wrong but the correct headers and correct y werent even close to fitting together. The driver side of the y sat about 12"s away from the header when installed. It took a local muffler shop which is very good at this stuff like an 1.5 hrs to make a pipe to fit this. It was next to impossible to get the y on to the headers and the driver side damn header points way over to the left so the drivers o2 is about 1/4 away from the floor. Plus the y which is a piece of **** in itself really rubs the tunnel brace. It took a total of 14hrs to install this setup with my buddy from the muffler shop doing most of the work. Hooker stuff is crap. I guess you get what you pay for!
Old Jul 10, 2004 | 06:02 PM
Chris81's Avatar
Thats weird, I had no problems whatsoever. The only little thing I had to do was cut the heat shield on the driver's side for the O2 sensor.
Sounds like something was wrong with your Y pipe.
Old Jul 10, 2004 | 06:07 PM
flexybronc's Avatar
ya, its almost like the driver side was meant for a cat and the other side is correct. Oh the other weird thing is that i removed the rear o2's and did not install any sims. There is still no ses or check engine light after 25 miles. There is one good thing there was actually a seat of the pants difference form my edelbroch shorties and catted y.
Old Jul 10, 2004 | 06:17 PM
ELS1's Avatar
thats strange...i have the cheaper headers made by Hooker: Flowtech...same design...and everything fit perfectly except for a little bit of vibration which u only feel when you are idling in drive...everything fit in kinda smooth..
i would call hooker and maybe they can see if they sent you the wrong Y...
Old Jul 10, 2004 | 06:22 PM
flexybronc's Avatar
ya i guess. I got my stuff from thunder racing and the instruction sheets have the correct part number on them it is so weird and bittering
Old Jul 10, 2004 | 07:03 PM
pontiac's Avatar
hooker ory is two peacis it sounds lioke you only got the y part and not the 12" 2ed peace it is supossed to come with??? my when on gerat
Old Jul 11, 2004 | 01:53 PM
flexybronc's Avatar
that sounds exactly right. so i guess there was supposed to be a little 12" piece with the y. Did yours have a bend in it and a notch so it wouldnt hit the floor.
