0411 upgrading, swap, rewrite?????
Old Feb 8, 2019 | 05:41 PM
jon1440's Avatar
Default 0411 upgrading, swap, rewrite?????
I have a 12200411 / 12212431 ecm in a 2002 Silverado. I want to add e85. Can I take 12200411 / 12216125 and just write over mine? The tune I will be using is from a 2002 Tahoe e85 found on HP Tuners Tuner Repository. So basically is my module capable of running 12216125?
And if anyone knows, does 12200411 / 12216121 have Flex enabled?
Thanks
Old Feb 8, 2019 | 07:24 PM
B52bombardier1's Avatar
You might also need to change fuel injectors that support E85.
Rick
Old Feb 9, 2019 | 12:09 PM
jon1440's Avatar
I currently have the physical supporting mods just need to know if i can write over my tune. Both systems (mine and the one I want) use the 0411 but the service number (I guess is what it’s called) is different. Only difference is the flex stuff. From all the research I’ve done I’m thinking I can. Just going to cost more credits. I would pick this option first if possible. My other option is take a physical module I have and swap them under the hood, then read it, license it and start over. Not sure which one is more costly. The only hiccup with doing this is the module I have I specifically pulled from an 02 Tahoe with all the flex stuff, (stainless fuel tube between fuel rails, e85 sticker on tank door, etc...) but the service number is 12216121 instead of 12216125, which everyone says to use. The 6121 service number is almost nonexistent on net. I only found one thread that talked about it. But nothing to do with what I’m doing.
