Non Trac Control Throttle cable??
Old Feb 10, 2019 | 08:56 PM
LS1Silverado05's Avatar
Default Non Trac Control Throttle cable??
So I have a 2000 SS which originally had traction control or ASR if you will, however it now has a 9 inch without speed sensors so I’m just deleting that part. I want to remove the unit on the passenger fender to clean up the engine bay and make room, but of course the throttle goes to that unit and then over to the throttlebody. Does anybody know if I need a non ASR cable or can I do something to make it all work?
Second part is if you have one let me know 👍🏼
Old Feb 10, 2019 | 09:31 PM
Just get a non-ASR cable and hook it up.
Old Feb 20, 2019 | 10:15 PM
Firebirdmuscle's Avatar
You will need a new throttle cable from a non tcs car. You can hit up hawks, they will have it. I did the same thing last year and removed that on the fender.
You will also need a non tcs cruise cable if you want to keep cruise. The cruise cable you can swap out in the cruise module also.
Old Feb 23, 2019 | 06:59 AM
cookseyb's Avatar
Locar makes these cables I think...
