Eletric Power Steering
Old Feb 22, 2019 | 03:58 PM
panda240ss's Avatar
Default Eletric Power Steering
Has anyone done it? i tried searching and found threads with broken pic links or such
Old Feb 22, 2019 | 06:33 PM
Maybe use the acronym EPS or EPAS (electric power assisted steering). You never know...
Old Feb 22, 2019 | 06:39 PM
LLLosingit's Avatar
https://ls1tech.com/forums/suspensio...er-issues.html
Old Mar 2, 2019 | 03:44 PM
xrtim's Avatar
Just about to order the DCE Microsteer for my Ultima Evolution build, One of the guys on the Ultima forum has already fitted one and likes it (It’s The best mod I’ve done on the car) dial or speed sensitive options
Old Mar 3, 2019 | 07:52 PM
ASRoff's Avatar
I'm looking to do a electric/hydraulic pump.... like a volvo or mini electric pump..... I'd rather not spend a lot of time under a dash trying to splice that into the column …..
Old Mar 4, 2019 | 07:40 PM
wannafbody's Avatar
Just buy a new Mustang if you want electronic steering. Manual steering is for real men.
Old Mar 4, 2019 | 08:09 PM
LLLosingit's Avatar
Manual steering if for drag racing, Real men use their car for more than that.
Old Mar 4, 2019 | 11:44 PM
80/TA/LT1's Avatar
I just did a Volvo electric power steering setup on my fourth gen, I’m loving it. $90 for the pump and $60 for a custom made pressure hose, had the wiring stuff laying around. I recommend it for sure
 Michael S. Palmer
Old Mar 5, 2019 | 07:36 AM
Darth_V8r's Avatar
Moderator
I daily drive my manual steering
Old Mar 5, 2019 | 08:12 AM
HioSSilver's Avatar
I looked into eps once put decided to skip it. With the belt set up on a fcar it's pretty easy to bypass the ps and only run the alt once you have a ewp.
Darth has huge gonads with hair *** thick *** a gorilla on them for dd no ps.
Old Mar 5, 2019 | 09:02 AM
Darth_V8r's Avatar
Moderator
That's a lot better than T-Rex arms...
Old Mar 10, 2019 | 09:04 AM
Old Geezer's Avatar
Question Details on
The install?
Part numbers?
Part sources?
I may do this w/ my 55 chevy/Ls conversion.
TIA,
Old Mar 10, 2019 | 11:53 AM
Project GatTagO's Avatar
I documented EPAS installation in my 67 Cougar.
https://ls1tech.com/forums/conversio...videos-23.html
Starting around post 913.
Andrew
Old Mar 10, 2019 | 11:57 AM
Has he commented on the return to center characteristics of the MicroSteer?
Andrew
Old Mar 13, 2019 | 05:13 PM
xrtim's Avatar
Andrew
No more information or install pictures have been posted, do you know of a problem with the unit?
Old Mar 13, 2019 | 07:32 PM
I don't have first experience with the MicroSteer. I was hoping to hear that it has good return to center, because my Toyota Prius steering doesn't have great return to center. I do have it integrated with my Holley Dominator ECU to make it automatically speed sensitive.
Andrew
