Mounting MAP sensor front vs back on FAST 102?
Old Feb 22, 2019 | 07:49 PM
98RedBird's Avatar
Default Mounting MAP sensor front vs back on FAST 102?
So from what I understand, the 102's place the MAP port in a different location than the 92. This leads to clearance issues with the f cars.
I know that the FAST gives the option to either drill out the front or the rear.
Which location are you guys going with?
If I choose the front does this affect tuning? Is the rear a better location for a measurement? Does it matter?
Also, will I need to fabricate an extension harness or are their premade ones that look more factory?
Thanks
Old Feb 22, 2019 | 08:44 PM
jaxcam02's Avatar
When I changed my intakes I debated on buying the extension harness for the front. I decided against it and reused the rear. As far as I am aware, it's a personal preference that really shouldn't make that big of a difference. Fast allowe you to choose based on which engine you have. LS1s in the rear. Ls2s in the front for example.
Old Feb 24, 2019 | 11:23 AM
td1168's Avatar
It’s seems like this is a “hit and miss” thing. I would personally locate mine on the front behind the throttle body to be safe and for accessibility. I first ran my map on the rear and it got broken off. It is now located on the front of my 99 trans am. No tuning problems and I bought the extension from summit racing for around $30.00
