fuel injectors are fitting very loose
0280158051 0 280 158 051
The 0280158051 is a stock ls3 injector. It is 42lb at 58psi, It has a us car plug and is 38mm o ring to o ring. The Bottom orange o ring will not fit in a ls1 or ls6 manifold. Call 770-888-1662 on Monday. Those guys can get you hooked up with what you need.
