Collapsed Oil Filter!
Old Apr 9, 2019 | 05:15 PM
Carp's Avatar
Default Collapsed Oil Filter!
Well for the first time in over 20 years of wrenching I went to change my oil on an 04 Silverado I just acquired and the cheap “speedy lube” crumpled like a coke can against my wrench. Apparently the hulk tightened it. I’ve tried to used a flat head and hammer it free but no luck. My last option is to take the oil fitting loose from the oil pan and attempt to get the filter off it or get a new fitting. Does anyone happen to know the size needed to get it loose? All mine are either too big or too small.
Old Apr 9, 2019 | 05:23 PM
The fabled Reynolds Wrap oil filter...… Been there, but lucked out and got it off. PITA though....
Old Apr 9, 2019 | 05:28 PM
01CamaroSSTx's Avatar
Those MFR's! You just gotta love them speedy lube centers.The're bad about over tightening the oil pan bolts too.
Old Apr 10, 2019 | 08:31 AM
Carp's Avatar
From what I read it’s a 17mm but I tried one last night and it didn’t work. Looks like a 14-15mm so gonna grab standard and metric sizes and try today
Old Apr 10, 2019 | 08:36 AM
The drain plug is 15MM and like I said those MFR's
Old Apr 10, 2019 | 08:51 AM
Carp's Avatar
It’s not the drain plug. It’s the oil filter adapter that the filter screws on to. A hex socket should get it out.
Old Apr 10, 2019 | 09:35 PM
Oh I see what your talking about now. I've never removed one from the engine block, Did you find what size it was and remove it?
Old Apr 11, 2019 | 02:24 AM
saccitycorvette's Avatar
LS1Tech Sponsor
Hi,
Its a 13mm or a 1/2" will also work.
Thanks
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
 Michael S. Palmer
Old Apr 11, 2019 | 05:32 AM
Carp's Avatar
1/2” hex socket got it right out with ease. Filter is froze to it. Have a new one coming in today.
Old Apr 11, 2019 | 07:23 AM
One reason to opt for the K&N but I still just tighten by hand and give a 1/4 turn.
Old Apr 11, 2019 | 08:04 AM
Carp's Avatar
I always use k&n and only go 1/2-3/4 past snug hand tight. Just did the wife’s 2012 Escalade a week ago. This is just the joy of buying a used truck.
Old Apr 11, 2019 | 06:11 PM
03Sssnake's Avatar
almost makes you wonder if the previous owner really pissed off the shop and some lube jockey put that bitch on with red locktite...
Old Apr 12, 2019 | 08:53 PM
No kidding! Not sure if the OP tried this on a cold engine but I assume once the engine is heated up it would have came off easier.
Old Apr 13, 2019 | 01:02 PM
Carp's Avatar
It was fairly warm but I’ve leaned my lesson with changing oil on a full temp truck. I tried heating it and it still wouldn’t come out. New plug went in fine and I’m running 40 psi at idle and 60-80 when I romp on it
