Newbie with LS 6.0 Firing issues
Old Apr 14, 2019 | 08:05 AM
Tom Martin's Avatar
Default Newbie with LS 6.0 Firing issues
I am helping a friend who has a LS 6.0, which my scanner tells me it came out of a 2004 GMC Denali. It's in a 50 ford pickup and it's running rough as a cob, however, it ran great 6 months ago. I put a timing light on each plug wire to see if they were firing. I am getting fire on cylinders 8,3, and 5. I also pulled the wire from the coils on all cylinders one at a time. These same three cylinders bogged the engine down when I pulled the plugs from the top of the coils, and none of the rest did.not. Have I had 5 coils go bad? The truck has been sitting for probably six months, and it's in a garage, but it has a rock floor and there is a LOT of moisture in the garage. Could that be a factor? Any suggestions? All help is greatly appreciated.
Old Apr 14, 2019 | 11:40 AM
Check for corroded connections EVERYWHERE, including ALL grounds.
Old Apr 16, 2019 | 05:41 PM
00pooterSS's Avatar
If it stays in storage a bit check all the wiring real close for damage from rats.
After that I'd look at the crank sensor.
No fire randomly on 5 coils isn't very likely to be caused by the coils just all the sudden failing.
Old Apr 17, 2019 | 09:18 PM
jetech's Avatar
Veteran: Air Force
Wow! I'm suprised it will run on 3 cylinders. I agree with 00pooterSS check the wiring for critter damage. Hurry before they chew through the remaining wires
