Gauge cluster shuts OFF
Old Apr 19, 2019 | 09:33 PM
freeridesnomore's Avatar
Default Gauge cluster shuts OFF
Guys, had a weird issue today while driving I noticed my gauge cluster every gauge besides voltage and I think OIl Pressure went dead including tach and speedo and odometer lcd. The odd part is if I press in the clutch it comes back on and works perfect let off the clutch and it goes away.
Anyone have any Ideas? 2000 Camaro ss 6speed
Old Apr 19, 2019 | 10:00 PM
I suspect a bad/loose connection and/or ground
Old Apr 20, 2019 | 02:42 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
If it were me, I'd take the cluster out and inspect it and the harness. You can also take your fist and beat on the (not TOO hard) passenger side of dash and see if it flickers that way. It could be a solder going bad/cracked on the BCM.
Old Apr 20, 2019 | 02:46 PM
wannafbody's Avatar
I had a similar issue in my E150 van and it was the connector going into the cluster.
Old Apr 25, 2019 | 01:19 PM
pillagenburn's Avatar
If you have T-Tops and they've leaked a lot over the years it could be corrosion from water/moisture somewhere in the harness causing a short. I don't think I've ever heard of a gauge cluster going out?
