idler pulley and bolt sizes
Old May 16, 2019 | 05:56 PM
jtl12419's Avatar
Default idler pulley and bolt sizes
98 Camaro style LS engine (obviously not in a Camarro)
I want to mount a small idler pulley on one of the bolts on the factory alternator support bracket.
Anyone know of a size of bolt to use, and idler to use.... part numbers get bonus.
Thanks.
Old May 17, 2019 | 06:45 PM
RB04Av's Avatar
The bolts are generally 10mm std thread, whatever that is... 1.5mm I think?
Define "small" in the context of an idler pulley.
Any idea how far from whatever you want to bolt it to that the belt will run? That probably should influence your choice as well.
