Went from TSP Dumps to their Over-The-Axle Setup
Old May 19, 2019 | 11:55 AM
M4N14C's Avatar
Default Went from TSP Dumps to their Over-The-Axle Setup
Been running the TSP dumped setup but the drone was driving me deaf. Switched to their over the axle setup and I was surprised how much better it sounded. Just as loud if not louder but a lot quieter in the cabin.
Fitment is good, however I'm lowered on stranos so I only managed to keep a couple inches of ground clearance. I also had to get creative in mounting the system after the axle. I'll still be tweaking the system so stay tuned. It sounds absolutely evil though...
https://youtu.be/ZADyxDQ1Evg
Old May 19, 2019 | 12:50 PM
Man, you got some SERIOUS rubber on there! PLUS suspension mods! Do you autocross?
Old May 19, 2019 | 02:34 PM
M4N14C's Avatar
Yup! She grips pretty good, surprise lots of people at the track.
Old May 19, 2019 | 08:49 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Hopefully you can find someone that can weld stainless. Cut and tweak as needed. That ground clearance is absolutely horrible.
Old May 19, 2019 | 10:48 PM
wannafbody's Avatar
Yikes, that's low
Old May 20, 2019 | 05:42 AM
fst100's Avatar
whats with the blue/greenish stuff on the suspension/bushings parts?
Old May 20, 2019 | 09:26 AM
M4N14C's Avatar
Yikes, that's low
Still need to adjust some more. My old setup was just about as bad... you learn to live with it. I'm also thinking about going for a a stiffer spring in the rear that will also give me a bit more clearance. Stranos are really soft.
Gender reveal burnout... it's a boy
Old May 20, 2019 | 07:23 PM
dr_whigham's Avatar
The Scammer Hammer
I had my TSP dumps cut and welded at a shop. Ground clearance was great. Hopefully you have a shop around you. I'd have it all welded except for a few joints just to aid in disassembly. It will help tremendously.
Old May 21, 2019 | 09:57 AM
Matt_ws6's Avatar
Keep adjusting, it will get better. I still need to cut and re-weld to see if I can get it perfect
