anyone else experience this or is it just my luck
Old Jul 12, 2004 | 03:17 PM
Nsty98LS1's Avatar
Default anyone else experience this or is it just my luck
i recently installed a tci ssf3500 and 24,000lbs cooler. after install i notice my temp goes to 210 pretty quick in town. as soon as i get rolling on the highway or anywhere i can get some moving air the temp goe right back down to where it normally runs. i assume this is from turning more rpms with lack of airflow. the car never overheats, so i am planning on installing a 160 t-stat and a manual fan switch. i just want to know if everyone that has a converter has the same issue?
Old Jul 12, 2004 | 03:30 PM
2_wacko's Avatar
I am going to chime in but I don't now alot about auto tran's.It might be because of the TCI being at 3500 it might be a little to high for daily driving.
Old Jul 12, 2004 | 03:47 PM
blkZ28spt's Avatar
You just need the low speed fan to come on earlier. I put a fan switch in a year ago, but when I had the tuning done for my converter I had them change the fan settings and now the fans come on eary enough I don't normally even use the fan switch
Old Jul 12, 2004 | 03:49 PM
Z'mnypit's Avatar
Mine did the same thing.. My I have the same exact set up.. my problem was the trans cooler was mounted on front of the air condinser & we all know that is right in front of the raditor. I have a 160* therm but no tune so the fans wouldnt ever cut on till 210* That was heating my trans cooler. But like you said once I strat going down the road it would cool off..
