Holley Sniper midrise questions
Old Jun 2, 2019 | 05:34 PM
boostwhipped24's Avatar
Default Holley Sniper midrise questions
Need some help. I'm installing a Holley sniper mid rise on my 01 Camaro.
1) it has 4 vaccum port on the bottom , I'm not sure where they all go. I know the big one is the Brake booster
2) where are you guys mounting the MAP sensor at on this intake. I'm not seeing much info out here.
Old Jun 2, 2019 | 07:36 PM
Whatever connections were on your old manifold connect to those. There are likely more than you need.
Old Jun 2, 2019 | 07:59 PM
Darth_V8r's Avatar
Moderator
Put a barbed fitting in and run a hose to map. Ditto for brake booster, AC and PCV. If you have an extra hole plug it
