Can oil ruin a starter?
Now that I have everything back together, the starter will not crank. I turn the key to the start position with my foot on the clutch pedal, and the car acts like I don't have the clutch pedal depressed.
Could the engine oil from the leaky rear main seal ruin the starter? Or do I need to look at the clutch pedal position switch?
Nothing to worry about.
Check for 12V at the solenoid, and if it's not there (probably not), track your way back through. Clutch pedal switch is a very likely candidate.
