Another damn PCV question
Old Sep 11, 2019 | 04:51 PM
Knightmare1981's Avatar
Default Another damn PCV question
I know this topic has been beat to death, but I just cant find the answers I'm looking for. I've got a '98 Z-28 that I'm swapping heads on, going from perimeter bolt to center bolt valve covers, the valve covers are from an '06 ls2 with only one tube on the passenger side and a capped nipple on the driver side, also using stock ls1 valley cover. My question is, can I run a hose from the rear driver side nipple to a catch can (vented) and a hose from the tube on the passenger side to the other port of the catch can? If I can, would I also need to put a PCV valve on both lines? Or am I going to have to get an ls6 valley cover?
Old Sep 11, 2019 | 07:03 PM
Majestic9C1's Avatar
If catch can doesnt have built in PCV valve you would need to add one in the blue colored line
Old Sep 11, 2019 | 08:21 PM
Ok, but do I have to run a line to the intake? Can I just run a line from each valve cover to each port on the vented catch can?
