2 piece timing cover questions
Old Sep 25, 2019 | 06:52 PM
FCar2000TA's Avatar
Veteran: Air Force
Default 2 piece timing cover questions
I am thinking of getting a 2 piece timing cover with my heads/cam next year, so I can get a cam for NA now and the swap will be easier when/if I get a blower down the road.
Do any work with double roller timing set ups?
Do any have leaking issues?
Is oil pump clearance still an issue?
Old Sep 25, 2019 | 07:28 PM
If you're only going to change the cam once, just stay with the stock setup. LS cam changes are pretty easy compared to the old small blocks.
Old Sep 25, 2019 | 08:22 PM
FCar2000TA's Avatar
Veteran: Air Force
Yeah, I was thinking after I posted that.... the Magnuson install will require the engine to come out, so that just about negates the need for a 2 piece timing cover.
