LS1 starts but wont run....
Old Oct 28, 2019 | 09:23 PM
Yukon56's Avatar
Default LS1 starts but wont run....
Aloha folks,
I know this is not a new subject..but here I am brining it up again. I have a LS1 put into my 56' chevy truck. I had a wiring harness built for it from a builder down south. I have a brand new fuel tank and pump, which seems to be working just fine. I've tested the fuel pump relay and it appears to be working as it should. ( although i did read someone suggesting its meant to be 5v from the pcm, it looks like I have 12v being sent from the computer). I have the battery ground to body, body ground to engine, engine ground to frame, harness ground to engine and PCM ground to battery.
One thing of note is that I do not currently have my MAF connected. I bent a pin connecting it, and I can't get a 150.2 terminal here in town. Its on its way but i've read it should still be able to start fine without it for the time being. I also do not have my O2 sensors connected, as its still just headers. All other sensors are connected and the engine has coolant and oil.
The fuel pump primes, then clicks off the relay until i crank it. Starts right up, sounds smooth but dies out anywhere from 1-3 seconds afterwards. Its an abrupt stop. I don't have a node light or a fuel pressure gauge at the moment...
Do you guys think have the MAF unplugged would cause this issue? I believe VATS has been turned off from the tuner who built the harness but I'm going to send him and email to confirm. I've checked the cam and crank sensors, to be sure they were connected...any thoughts?
Thanks. Matt
Old Oct 28, 2019 | 10:30 PM
VATS strikes again.... You need to program the Vehicle Anti-Theft System out. It allows it to start and run abut 2-3 seconds, then kills it
Old Oct 28, 2019 | 11:24 PM
Yukon56's Avatar
Have you tried using a different vehicle to swap PCM's to reset the VATS system? Or do you suggest sending it out to get it tuned out? There are a few videos around of folks using donor vehicles or disarm the security key..
Old Oct 28, 2019 | 11:54 PM
In a swap situation like yours, unless you are using the same key and ignition switch that came with the car the engine came out of, you have to program it out. Call LSX Power Tuning for help on this.
Old Oct 29, 2019 | 01:07 AM
LLLosingit's Avatar
Originally Posted by Yukon56
Aloha folks,
I
Even if you get the vats figured out I wouldn't try running it until you get the MAF and O2 sensors connected.
Old Nov 23, 2019 | 02:56 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Sounds like vats. If you never had it happen... You can't hands down say it is. Its happened to me. It'll crank up and stay running for 3 seconds and cut off like a bad pump. Everytime, instant crank and run, but cutoff in 3 seconds. Have your tuner delete the vats out asap. I suggest hiding a cutoff switch tho just for insurance.
