Cam suggestions for LM7 with 862 heads
Old Nov 9, 2019 | 01:15 PM
Purebreed1's Avatar
Default Cam suggestions for LM7 with 862 heads
Thanks for reading my post. I have an old project I have been working for years with my son. He is now off to college and I have the itch to get this thing running. The project I have is a 1973 Camaro RS. I have been a part of the NastyZ site for years and have gained a bunch of knowledge from that group.
I picked up a a 2002 LM7 with 862 heads and a 4L60E trans. I plan to do the swap this spring. I have been accumulating the parts needed for the swap. So far, F- body oil pan, LS6 intake with rails and injectors, timing chain, oil pump, gasket kit etc. As with most I am trying to keep the budget in mind because these swaps snow ball quickly. I will be changing the rear end gears to at least a 3.42 or maybe even 3.73. I have a line on a Z06 cam but the more I read the more I think I would be much happier with the aftermarket offerings. I have read that Elgin 1840-p or the SummitStage 3 Truck: SUM-8713: .545/.545 - 222/231 112+5 cam may be a nice option. I am looking for good all around cam. Suggestions from those that have a similar setup as I have?
Old Nov 9, 2019 | 01:32 PM
LM7s came with 862 heads. The issue with the Z06 cam is its very wide 117.5 LSA, and late IVC, both of which suck out a lot of low end power.
Old Nov 9, 2019 | 03:22 PM
Purebreed1's Avatar
Exactly why I am looking at my options. The Z06 cam was free but if I am going to go through the effort and the motor is sitting on a stand might as well stab something in there that is worthwhile. Any suggestions?
Old Nov 9, 2019 | 03:57 PM
How much power are you after, and how will it be used?
Old Nov 10, 2019 | 09:56 AM
Bspeck82's Avatar
What converter? What life will it see? Vehicle weight? Any head work getting done? Compression ratio?
Old Nov 11, 2019 | 07:58 AM
Purebreed1's Avatar
The car is 1973 Camaro RS/LT. She is a bit heavy at 3400Lbs. I assume the compression will be factory LM7 numbers. I don't have any power goals in mind. For conversation sake around 330HP+ is a good target. The car will never see the drag strip but would like to have get up and go. I have a 450RWHP 1986 Mustang to thrash if needed. I have not purchased the stall as I understand that I need to match the cam and the stall. The price of the Summit cams are pretty reasonable and fit my budget.
Old Nov 11, 2019 | 10:30 AM
OK, with the cam you have in mind you might want to get the heads mildly ported, mainly a bowl blend and multiangle valve job. Use a good 2-1/2" dual exhaust and a decent CAI.
Old Nov 11, 2019 | 11:58 AM
Purebreed1's Avatar
I currently running the Pypes SS exhaust with x-pipe. I plan to use that with this swap. I am going to give Summit a call and get some suggestions from them on a cam. i will let you know what they recommend for my application.
Old Nov 11, 2019 | 12:18 PM
JoeNova's Avatar
Restricted User
I really like the new Summit cams. They won't steer you wrong.
Old Nov 11, 2019 | 12:26 PM
Purebreed1's Avatar
Trying to avoid head work if possible. At some point when the motor needs to be rebuilt I may look into some new heads that flow better. For now I am going to swap the cam, intake, TB, electric fan, and a torque converter.
Old Nov 11, 2019 | 01:55 PM
wannafbody's Avatar
Summit stage 1 or stage 2 would probably be good. I don't think I'd go bigger on a 5.3.
