Difference between ac delco tps sensors
Old Nov 10, 2019 | 08:00 PM
blackfbird98's Avatar
Default Difference between ac delco tps sensors
Looking to replace my tps sensor for my 2000 z28 but I keep coming up with two possible ac delco sensors, one is 213-912 the other is 213-4668 does anyone know the difference between the two and which one I should get??
Old Nov 11, 2019 | 07:17 AM
Anyone have any idea???
Old Nov 11, 2019 | 10:27 AM
Give it a little more time... you just posted last night.
Old Nov 11, 2019 | 01:58 PM
trilkb's Avatar
I thought one might be a GM dealership part and one might be a lesser quality auto store part, but who the F knows.
Old Nov 11, 2019 | 02:23 PM
bammax's Avatar
912 is the OEM Series and 668 is the Professional Series. The OEM series is made in a Chinese sweatshop using mediocre materials, while the Professional series is made in a Chinese sweatshop using inferior materials. On rockauto the higher quality 912 is actually cheaper for some reason.
Old Nov 19, 2019 | 05:43 PM
dreadpirateroberts's Avatar
912 is original equipment. when getting acdelco part, get original equipment, since it should be made to the same standards and specs as what came with the car.
Old Nov 23, 2019 | 01:47 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
1 is prob a old stock#. GM has made new part#s for a lot of things as time goes on. I've taken tps from northstar or v6 engines and run just fine on my ls1s. If harnwss plugs in... Your good. o2s... If same style connector etc is same... Different part#s are bc of wire length. Bosch just redid theirs for the vette o2 that we love to use in fcars with long tubes. Had a warrenty issue on my just last week and found that out lol
