Texas Speed Duals
RedReaper, I'll keep you in mind.
If you install the system on a drive-on lift where the rear axle is supported at right height it has about 4 inches of ground clearance. I installed a set on a 01 Z with the Eibach Pro-Kit and it tucked under just fine.
I'm not sure if it will fit Kooks or not, I've never installed Kooks or seen them on a car to know for certain myself. If you have a L1 made, make sure its uncrimped 3" mandrel bends, only a few exhaust shops do true mandrel bends.
