Head swap, safe to drive before tune?
Old Dec 8, 2019 | 02:49 PM
ATXSS's Avatar
Default Head swap, safe to drive before tune?
Sup fellas, just put some PRC 2.5 5.3 heads on my LS1 that had already had a cam/tune done. Think it's safe for me to drive about 30 miles or so to get it tuned? Wanted to stab on it a couple of times as well to make sure everything is working fine.
Old Dec 8, 2019 | 05:09 PM
Darth_V8r's Avatar
Moderator
You will be fine. I might hold off on stabs Incase you find it a bit lean at high load due to flowing more air with your new heads
Old Dec 8, 2019 | 06:18 PM
ATXSS's Avatar
10-4 thank you sir. I will not press my luck and stay off of it.
Old Dec 10, 2019 | 08:00 AM
Know It All's Avatar
If you have the same old injectors on it, you should be fine for cruising and part throttle.
