Harmonic balancer
Old Jul 14, 2004 | 07:46 PM
95 LS1 Camaro's Avatar
Default Harmonic balancer
I picked up a used 02 LS1 and the harmonic balancer is not installed. I noticed there is no keyway. Is it safe to assume that it can be installed in any position? Also what torque should the bolt be tightened to? Thanks in advance.
Old Jul 14, 2004 | 08:08 PM
ace68's Avatar
there is no need for a key because there is a sensor in the engine for the timming. and torque is 240ft lbs with old bolt then 37 ft lb with new bolt then 140*
