BBK Fuel Rails
Old Dec 14, 2019 | 03:54 PM
Restovet's Avatar
Default BBK Fuel Rails
I have a LS6 with the stock manifold. I installed BBK fuel rails as per instructions.Also I put new o-rings on the stock injectors.When I checked for leaks there were none .I wanted to bleed the air out of the system and cracked one of the end rail caps open. I held the rail with one hand on loosen it with the wrench. As I was pulling to unscrew the end cap fuel was squirting out of the top of the injectors on that rail because of being twisted a little. Is this normal? Anyone else experience the same thing? I was wondering if this is going to be a safety issue with these rails. Any help would be appreciated.
Old Dec 14, 2019 | 10:37 PM
Yes. You disrupted the seal between rail and injectors. Once correctly re-aligned it should be fine. O-rings won't seal well when misaligned temporarily.
Old Dec 18, 2019 | 07:15 PM
LilJayV10's Avatar
If you want to bleed the air out of the fuel system, turn the key till it starts.....
