What size injectors?
Old Jan 29, 2020 | 10:44 PM
DustyNova442's Avatar
Default What size injectors?
I finally got it put together its a 427 ls next running AFR 230s 10:5:1 compression and a 222/230 cam on a 112 LSA and a fast 92 what size injectors would i probably need (fyi i know the cams smaller but its not going in a vette or camaro its actually going into a 1500hd)
Old Jan 30, 2020 | 04:32 AM
Darth_V8r's Avatar
Moderator
Stock ls7 injectors. Unless you want to run e85. Then use 60 lb
