Spare inlet on DBC TB
Old Mar 9, 2020 | 01:07 PM
RoverSwap's Avatar
Default Spare inlet on DBC TB
Hey all cross posting this from the newbie thread since I never got an answer there.
Intake manifold is off a 2004 Envoy XL that originally had a drive by wire throttle body. My swap requires a drive by cable setup.
I now have these two inlet ports that I think were intended for the PCV tubes coming off the valve covers?
Is that what these are intended for? if so should I use one for the passenger side and the other for the driver's side?
https://ls1tech.com/forums/new-ls1-o...ttle-body.html
Thank you!
Old Mar 9, 2020 | 02:32 PM
AwesomeAuto's Avatar
block one of them off.
Old Mar 9, 2020 | 09:03 PM
blsnelling's Avatar
Those are both for the "clean side" (supply side) of the PCV system. Use either one and block the other off.
