3" radiator concerns
Old Mar 28, 2020 | 12:21 PM
Bspeck82's Avatar
Default 3" radiator concerns
Hey did you guys have to cut up the fan shroud on the passenger side to clear the WP pulley? I had about an eight of an inch of clearence and I know the engine will flex enough to make contact. I don't see how I can make myself any more room.
Old Mar 28, 2020 | 04:49 PM
ddnspider's Avatar
Why do you need a 3 inch radiator? Either way cutting the fan shroud isn't the old way to gain room. You can gain quite a bit of room just by messing with the radiator angle. There's actually a small piece of the undersize/back of the upper radiator support that will gain you quite a bit of added room without actually cutting up the whole upper support and standing the radiator up.
