Anyone using Edelbrock 8896 water pump?
Old Mar 29, 2020 | 06:16 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Anyone using Edelbrock 8896 water pump?
Is anyone running an Edelbrock 8896 water pump? I think I am going that route with my LSXR 102 intake manifold.
Old Mar 29, 2020 | 07:22 PM
13qtr's Avatar
It should. I'm running it on my ls3(406) with a fast 102 in my 05 gto
Old Apr 1, 2020 | 01:04 PM
FCar2000TA's Avatar
Veteran: Air Force
What about the Evans water pump? Is that the same as an LS1 housing, or an LS2 housing?
Old Apr 1, 2020 | 01:14 PM
Bspeck82's Avatar
Read your other thread. You shouldn't need a fancy water pump unless you want one just to say you have one. Get an act Delco off Amazon or get one at AutoZone with a lifetime on it and call it good. Make sure it's the ls2 version.
Old Apr 1, 2020 | 01:24 PM
FCar2000TA's Avatar
Veteran: Air Force
I read somewhere that the LS2 pump doesn't flow as well as the LS1, is that accurate?. Also, I intend to upgrading the cooling system at some point, and a higher flowing water pump would be a component of that. I figure I might as well do it now, since I am replacing the water pump.
Old Apr 2, 2020 | 10:09 AM
SLP IROC-Z's Avatar
i havent tried an edelbrock pump, i now have a parts store gates ls2 pump, but it doesnt cool the car as well and i still had to grind a decent amount off it. once i get my meziere rebuilt ill be putting that back on.
Old Apr 2, 2020 | 05:49 PM
wannafbody's Avatar
Are the LS1 and LS2 water pump pullies in the same position?
Old Apr 2, 2020 | 11:35 PM
Bspeck82's Avatar
Yup same pulley. No grinding required. Direct fit. Needs a two piece thermo housing.
I remember reading the one piece thermo works but I'd look into this if you choose to not get a new thermo. It's like 30 bucks for a 185 thermo
Old Apr 3, 2020 | 12:04 AM
FCar2000TA's Avatar
Veteran: Air Force
LS2 water pump = pn 12681186. I think that part number comes with the 2 piece thermostat too.
