Coolant crossover woes
Old Apr 5, 2020 | 06:41 PM
Bspeck82's Avatar
Default Coolant crossover woes
I have the ls6 crossover tube with rear block offs. I replaced the gaskets with felpro rubber o rings and all 4 are leaking very slowly. The felpro o ring doesn't protrude as much as the ones it came with. Should I buy a set of coke tab gaskets or the $8 gm gaskets? Price not a factor I need something that works.
Old Apr 7, 2020 | 05:43 PM
wannafbody's Avatar
I'd guess GM would work.
Old Apr 7, 2020 | 07:28 PM
Bspeck82's Avatar
Just bought some gm gaskets. We will see if this fixes it.
Old Apr 9, 2020 | 12:18 PM
00cls1camaross's Avatar
I know this is frowned upon, but I used a little bit of the blue silicon gasket maker on both sides of where the block off thingy meets the block. No issues anymore!
