C5 engine wiring harness question
Old Apr 12, 2020 | 11:12 PM
Camaro_09's Avatar
Default C5 engine wiring harness question
I have a 2003 c5 6 speed and I am doing a heads and cam swap. I pulled the engine to replace it with a lower mile engine. After I pulled the engine I noticed my wires for the starter and one ground wire are burnt together. I have thought about fixing them or just buying a new harness but it’s hard to find one. I am picking up a salvage 01 c5 auto to part out. Question is will the engine harness from an 01 auto work on an 03 manual?
Old Apr 12, 2020 | 11:28 PM
Corvette Ed's Avatar
If it’s not the same it should be close,you might have do a little splicing but it’s doable.
Old Apr 14, 2020 | 10:12 AM
R6cowboy's Avatar
Simply repair the couple burnt wires on your current harness if that's the only issue it has. The time and effort spent replacing the entire harness over a couple small burnt spots seems a bit silly.
Old May 6, 2020 | 12:03 PM
I agree this would be your best option.
