Round coil vs square coil, does it matter?
Old Apr 30, 2020 | 01:50 PM
G_Rapids's Avatar
Default Round coil vs square coil, does it matter?
I purchased an engine from a wrecked silverado. Unfortunately, it came with almost nothing, leaving me to piece together everything. I need to get my hands on some coils, but not sure if it makes a difference if i get square or round. I wont be using a stock wiring harness, going with a holly terminator setup, so it begs the question, is the wiring the same? is there advantages to one over the other?
Old Apr 30, 2020 | 02:01 PM
RB04Av's Avatar
They wire the same AFAIK, on a truck. The round ones are thought to be better but I doubt most builds would ever show a difference. https://ls1tech.com/forums/generatio...l-upgrade.html
Old May 2, 2020 | 11:25 AM
wannafbody's Avatar
Whatever ones fit the valve covers you have
Old May 2, 2020 | 01:29 PM
RB04Av's Avatar
Actually, both kinds fit all the truck VCs. Just gotta use the right brackets for whichever coils. Plug wires might be different; might not be exactly the same length, due to where the "tower" on the coil is located.
