Oxygen sensor position?
Old May 16, 2020 | 01:14 PM
kipps's Avatar
Default Oxygen sensor position?
Is the specific position of the O2 sensor critical? Or can I just clock it so as to be easily serviced?
In other words, does it have to be on a specific side of the exhaust pipe, or can it be anywhere within a few inches of the manifold?
I could imagine it might read different depending on what part of the exhaust stream it was reading from. I'm likely overthinking it, though.
Old May 16, 2020 | 03:38 PM
It's more about accessibility and clearance than function. Clock it with those factors in mind.
Old May 16, 2020 | 03:48 PM
kipps's Avatar
Thanks!
Old May 16, 2020 | 04:34 PM
68Formula's Avatar
You want to mount it at least slightly above horizontal, otherwise condensation can cause it deteriorate more quickly. So between 9 and 3.
Old May 16, 2020 | 04:48 PM
I've seen quite a few mounted on the bottom "edge" of a downward-angled pipe
