ls1 map sensor vacuum lines
Old May 30, 2020 | 05:33 PM
retromod73's Avatar
Question ls1 map sensor vacuum lines
Hey guys, I've swapped a ls1 into my 73 camaro and have a question about the map sensor vacuum lines. On my 73 camaro I have a manual brake setup with no booster so what can I do about the vacuum line that goes from map sensor to the brake booster? I have heard you need it hooked up for the engine to run right or can i block it like the other line on the map sensor?
I have done some searching and couldn't find anything. Appreciate the help.
Old May 30, 2020 | 06:26 PM
RB04Av's Avatar
The MAP sensor needs a vac line that goes to the manifold and sends it a sample of vacuum. NO WAY the engine will run right without it,
Not really related to the brake booster except by accident.
Hook the MAP sensor to a nipple on the manifold and call it good.
Old May 30, 2020 | 06:31 PM
retromod73's Avatar
Alright cool I appreciate the response.
